Delayed playback while recording for broadcast
AricV
Post by AricV » Sun Nov 07, 2010 11:30 pm
I did a quick search and browse of the forums here, but I didn't see a solution to my situation.
First I will give a brief background. We are using Audacity to record live sound (Sunday church service) from a mixer for later duplication onto CD's. This service is also being simultaneously broadcast on a local AM radio station.
Now, for my problem. In a few weeks the service will be running 45-60 min ahead of its regular schedule. Is there a way/plug-in I can use to start recording the incoming audio and 45 minutes or so later start playback of the same audio without stopping the recording? The radio station will not do a delay for us, they will only transmit the live signal we send them. I have seen hardware that will do this, and even some software (http://www.broadcastdelay.com/) but since this situation might only come up once a year the cost ($1200)is not practical. (We could use the 30 day demo of the previously mentioned software to get around this one time) We currently only have one dedicated audio computer. We have tried to use a laptop in the past to try and record the first 45 minutes, but the recording quality was terrible, probably due to the sound hardware in the laptop.
I guess I could try and come up with (borrow) a better laptop, but if there is some way this could be accomplished with one system it would probably simplify things.
Re: Delayed playback while recording for broadcast
Post by kozikowski » Mon Nov 08, 2010 12:05 am
No. As you found, your job is serious surveillance software and since that's not a popular product, it's expensive. Yes, surveillance is the other place where you can record and play with no relationship to each other.
TiVos and DVRs do that. My EyeTV off-air tuner and DVR software can do that, too. I can, if I wish, start watching the 8PM show at 9PM while the 9PM show is being captured.
Can you record your show to a TiVo and also to Audacity? At the magic time, you reset the TiVo playback to the top of the show and press play.
