Cannot disable internal sound recording
sakura741
Post by sakura741 » Fri Nov 05, 2010 12:08 am
Hi,
I am using audacity version 1.3.12 and Windows 7. I am using headphones and trying to record audio JUST through my microphone. I also am using youtube at the same time to see how my audio would match with the music. However, even with the playback device set to 'headphones' and the recording device set to 'microphone', as well as the channel set to 'mono', I can't seem to make audacity only record the microphone sounds; it records the youtube music as well. Is there a way to disable it?
Thanks in advance!
Re: Cannot disable internal sound recording
Post by steve » Fri Nov 05, 2010 2:26 am
sakura741 wrote: even with the playback device set to 'headphones' and the recording device set to 'microphone'
Where are you making these settings? In Audacity or in the Windows Control Panel?
sakura741
Post by sakura741 » Wed Dec 15, 2010 10:53 pm
In Audacity. I did play around with the settings in 'Sound' from the Windows Control Panel, but nothing worked so I just reset it and tried to figure out Audacity instead.
Post by steve » Thu Dec 16, 2010 2:57 am
Could you say what the exact settings are that you have in Audacity "Edit menu > Preferences > Devices"
and also, what is set as the default recording and playback device in 'Sound' from the Windows Control Panel.
Also, what sort of microphone are you using and how is it connected to the computer?
Is there sound coming out of the computer speakers, or only through your headphones?
