problem labeling track
jbrennan1
Post by jbrennan1 » Tue Nov 02, 2010 2:45 pm
Hi--I am a new user, and cant seem to be able to correct a labeling mistake with a track. I made two track labels for one song, appropriately the song is
Emotional Release, stones . How can I remove the track label that was a mistake? Thanks
J
in Montana
waxcylinder
Re: problem labeling track
Post by waxcylinder » Tue Nov 02, 2010 3:17 pm
Just click in the label, delete all the text - and then one extra press of the delete or backspace key will remove the label. The quickest way is to select all the text in the label and press the Delete key twice.
Your'e lucky you're using 1.3 as that means you can see the second label - In 1.2.x the second label used to hide behind the first one - this caught several people out ...
