This just makes me wanna cry
Zero Emissions
Ok, so I haven't had any problems recording internet radio before....
I haven't changed ANYTHING on my computer, I just didn't use Audacity for a few weeks due to being homeless and having no electric.... now It has suddenly decided that it doesnt want to work anymore.
I mean I haven't touched a -------- thing and it just stops working. FLATLINE when im recording. The output and input levels dont work anymore.
Thanks a bunch
Thanks a bunch
Re: This just makes me wanna cry
I edited your post.
Which Windows? What kind of machine? Give us a push.
Zero Emissions
I am using a Samsung n150, windows 7. i had no problems before
If your computer is connected to the Internet (which I assume it is), check to see if it is possible to "roll back" the drivers for you sound card.
Zero Emissions
I managed to fix it by uninstalling an online game I had downloaded!!!
Zero Emissions
Thanks, and apologies for the swearin
Thanks for letting us know the happy resultZero Emissions wrote:I managed to fix it by uninstalling an online game I had downloaded!!!
Zero Emissions
I'm not sure what you mean by roll back. I dont know much about drivers, but my comp says that they are all up to date. I bought this laptop new a few months ago, will doing this improve my sound?stevethefiddle wrote:If your computer is connected to the Internet (which I assume it is), check to see if it is possible to "roll back" the drivers for you sound card.
im just glad to get it working cos i have found audacity to be the best program for my purpose
I posted that before your last message came through. If it's working now, leave it as it is.
