Monitoring using USB mic...delay in headphone playback
captain54
Post by captain54 » Tue May 06, 2008 12:50 am
I have an Audio Technica 2020 usb mic and a Dell, with SB Live 16 stock souncard....
I can record fine, no problems....
the headphone output from the sound card contains a substantial delay....I have
played with all the latency correction and buffer settings to no avail....
I have software playthrough checked, and I'm sure that's why I have latency in the playback...
If I uncheck it and just use hardware playthrough, I get no signal at all out of my headphones..I have
been playing with this for hours
is the answer an external mixer?
Re: Monitoring using USB mic...delay in headphone playback
Post by steve » Tue May 06, 2008 10:55 pm
captain54 wrote:I have software playthrough checked, and I'm sure that's why I have latency in the playback...
Spot on. Software playthrough is much slower than hardware playthrough, hence the delay.
captain54 wrote:If I uncheck it and just use hardware playthrough, I get no signal at all out of my headphones......
Do you actually need to hear the microphone through the headphones? Many people just adjust the level of what is coming through the headphones so that they can hear themselves singing/playing acoustically.
You should be able to get the other tracks to play through your headphones by selecting your sound card as the playback device in "Edit > Preferences > Audio I/O" and also selecting "play other tracks while recording new one"
captain54
Post by captain54 » Fri May 09, 2008 3:57 pm
stevethefiddle wrote: Do you actually need to hear the microphone through the headphones? Many people just adjust the level of what is coming through the headphones so that they can hear themselves singing/playing acoustically.
that's what monitoring is...you hear what you're recording into the microphone thru the headphones.
Post by steve » Sat May 10, 2008 2:00 am
Unfortunately the problem is that you are recording through one hardware device and playing back through another. The two devices are not connected (as they would be if you were both recording and playing back through the same sound card).
Audacity is able to send the audio from the recording source (the USB microphone) through to the playback device (your sound card), but since this is done through software, it takes a noticeable amount of time to get from the input to the output and this is what is causing the delay.
So yes, you can monitor the input, but with a delay which is unavoidable with this kind of hardware (unless your microphone has an analogue audio output).
