Recording meter stopped/frozen
putridmocha
I am recording from a tape deck and the recording will go so far and it will stop and the cursor will just flash
any help much appreciated
Re: Recording meter stopped/frozen
Did you run out of hard drive space? Audacity will not work into a full or badly fragmented hard drive.
Defrag
-- Right Click Start > Explore > Right Click Local Drive C: > Properties (Used, Remaining)
-- Tools > Error Checking & Defragmentation
A production hard drive should never be over about 80% or so full. The computer may start acting funny about the 90% point.
Defrag
Hardware memory problems can cause that, too, but that's much more serious. Hope for the hard drive.
Loosing a USB connection can cause that.
A crashed Flash browser plug-in can cause that.
Bad sound card drivers can cause that.
Can't really narrow it down without a lot more information.
putridmocha
The hdd is about 90% free and tried a defrag but still happening.
what info can i provide you with to maybe pin point the problem better?
Thanks for your help
What sort of tape deck?
How is it connected to the computer?
Is this a laptop or Desktop computer?
Which version of Windows?
"the recording will go so far and it will stop and the cursor will just flash" - How far is "so far"?
We can only work with what you tell us, so too much information is better than not enough
putridmocha
ok ta
its this tape player http://www.amazon.co.uk/Sony-TCM939-CED ... -3-catcorr
connected to the pc using usb to 3.5 headphone jack
desktop pc
windows xp
it varies but this is one i tried this morning
(it stopped at the time shown)
desktop pc
windows xp
(it stopped at the time shown)Re: Recording meter stopped/frozen
What is this "usb to 3.5 headphone jack"?putridmocha wrote: connected to the pc using usb to 3.5 headphone jack
I suspect that the USB connection has been lost. You could try connecting the USB to a different USB socket on the computer. Avoid using a USB hub - it must be connected directly to the computer.
Is this a Desktop computer? If so, try the USB connectors on the back.
You could also try using a "stereo 3.5 jack to 3.5 jack" if your computer has a "Line In" connector.
putridmocha
i tried using a different program and it worked fine so i guess that eliminates my equipment or hardware.
I would change programs but none comes close for user friendly interface
<<<i tried using a different program>>>
Which is? Stop using dark gray terms like that. You can't give us too much information. "I was able to use 32-bit Able-Audio® on my Dell Dimension Desktop machine with dual hard drives running Win7."
We can't see over your shoulder and we're not all Windows Mavens.
