Removing a Frequency from my file
js17
Post by js17 » Tue Apr 29, 2008 10:09 pm
I am trying to remove a specific frequency from my audio file. The noise filter does not help me, since I can't isolate where the frequency is in my audio file. I tried using the equalizer, but when I run it I just get a straight line.
Is there a tool that can allow me to remove a specific frequency if I know the band? I can learn how to use the tool on my own, I just really need help getting started!
Thanks in advance.
Re: Removing a Frequency from my file
Post by steve » Wed Apr 30, 2008 6:27 pm
The tool you need is the "Equaliser". If you're getting a flat line output, you are probably doing something wrong, but that is the tool to use.
js17
Post by js17 » Wed Apr 30, 2008 9:27 pm
OK. I'll read up on how to use it properly because you are right probably right about me using it wrong. Thanks for confirming that is what I should be using!
