New to Audacity and forums.
I'm using Audacity 1.3.12 beta, Windows XP Pro and a Blue Snowball (USB) microphone. When I'm recoring my voice and have the playback (software) feature turned on, there is a delay. I've read elsewhere in the forums that enabling the hardware playback option in Audacity>Preferences will fix the problem, but I don't have that feature availabe in Audacity.
Is there a fix or workaround where I can record my voice and hear myself at the same time?
Thanks for the help!
Delay hearing myself while recording with USB mic
Re: Delay hearing myself while recording with USB mic
Hardware PlayThrough is only an option on Macs, but it does not help with USB microphones anyway.cmdarr wrote:I've read elsewhere in the forums that enabling the hardware playback option in Audacity>Preferences will fix the problem, but I don't have that feature availabe in Audacity.
(On Windows Audacity defaults to "hardware playthrough" unless you enable "software playthrough").
Probably not.cmdarr wrote: Is there a fix or workaround where I can record my voice and hear myself at the same time?
Some USB microphones avoid the problem by including a headphone socket on the microphone itself (thus enabling "direct monitoring") but most USB microphones do not have this feature.
- Quality Assurance
Steve just pipped me to answering, but just to add that "Hardware Playthrough" in Audacity for OS X is a hack (that usually has no effect) to make up for the fact that Macs don't support playthrough at all.
The Samson Go is an example of a USB mic that includes an output from which you can hardware monitor with no latency.
Otherwise, the usual answer is to use a hardwired mic. Then with a sound device that supports hardware playthrough (unmuting playback of the mic or line-in) you will get a tolerable delay. There is no guarantee a motherboard computer sound device will actually support hardware playthrough even if the Windows Control Panel has a way to unmute the mic or line-in. In that case you won't hear any playthrough in Audacity until you enable Software Playthrough.
Thank you for the replies! Very helpful. It sounds like i'm going to need a different mic (if I want to hear playback).
Thanks again for all the help!
Several of the Samson USB microphones have a headphone socket for zero latency monitoring - Samson also have short vocal demonstrations of each microphone so that you can hear the difference between them http://www.samsontech.com/products/bran ... ?brandID=2Gale Andrews wrote:The Samson Go is an example of a USB mic that includes an output from which you can hardware monitor with no latency.
