Hello,
I have some G.729 wav files from our VOIP voicemail system that I need to open and convert to another format for ease of playback on other PC's. Is there any way to open these using Audacity 1.3.x? I tried opening the files, but get the error none of the importers support the file. Any thoughts?
Jim
Opening G.729 Wav Files
[email protected]
Re: Opening G.729 Wav Files
Audacity is a terrible converter. You should use Super or Switch (download).
[email protected]
can you please provide a link to those programs, I just googled them and came up with a bunch of similar names.
Thanks,
Jim
Thanks,
Jim
Top Google search result for super: http://www.erightsoft.com/SUPER.html
Downloading it is a link jungle, but it's worth the effort.
