1.3.4 used to work. won't open. reinstalled-still won't open
crispy
Re: 1.3.4 used to work. won't open. reinstalled-still won't
Post by crispy » Thu Aug 28, 2008 3:48 pm
Thanks - it appears that audacity is opening way off screen, maximizing works as a quick stop gap until I found the cfg deletion technique.
katefurr67
Post by katefurr67 » Tue Sep 30, 2008 8:22 pm
I just wanted to say thanks to everyone in the forum! I am using Audacity 1.3.5 beta with Windows XP and was having the same issue with the program showing in the taskbar but being unable to maximize it. For some reason I couldn't find the audacity.cfg file in the Audacity folder. I searched for it with Explorer, found it, deleted it and then reopened Audacity. That did the trick!
Kate
who is always grateful for the generosity of the geek community!
Post by steve » Tue Sep 30, 2008 9:57 pm
katefurr67 wrote:For some reason I couldn't find the audacity.cfg file in the Audacity folder
That's because it isn't in the Audacity folder. It's here:
Documents and Settings<user name>Application DataAudacityaudacity.cfg
You may also need to turn on "show hidden files"
( http://www.microsoft.com/windowsxp/usin ... files.mspx )
waxcylinder
Post by waxcylinder » Wed Oct 01, 2008 8:11 am
stevethefiddle wrote: That's because it isn't in the Audacity folder. It's here:
And that's so that Audacity 1.3.x can maintain a preferences file for each separate user (each user with a separate log in account on the computer) - thus affording greater flexibility.
tepeco
Updated for VISTA users.....
Post by tepeco » Thu Dec 11, 2008 7:29 pm
Just to update this information for VISTA users, I had this same problem on the newest version 1.3.6 and since I have the VISTA OS, here's a little revision on where to find the audacity.cfg file on VISTA. Opening 'my computer', the top icon is 'desktop'. The next icon bears the name I gave to this machine which for me, is GRAPHICS. Opening this folder (what ever yours is named on your VISTA machine), choose APPDATA>ROAMING>AUDACITY. The audacity.cfg lies in this folder. On my machine, which is set to always show all hidden files, for some reason, did not find this cfg file using the search feature! That was a surprise. It should have found it.
Anyway, the removal of this file solved my problem too. I'm pretty sure it was caused by clicking too fast, too many times, when opening the program to use it.
tepeco
