Programmable Recording Software for Internet Radio
Can anyone suggest a simple and inexpensive, easy-to-use Windows (Vista) program to recording Internet radio and other streaming audio that can be programmed to record specific shows at specific times?
- Quality Assurance
Re: Programmable Recording Software for Internet Radio
The Standard Edition of Total Recorder might suit you.ghe wrote:Can anyone suggest a simple and inexpensive, easy-to-use Windows (Vista) program to recording Internet radio and other streaming audio that can be programmed to record specific shows at specific times?
Thanks! That seems to be just what I was looking for.
