deleting mutli tracks
phantasm777
i have searchd as best i could and could not find a way to hilight the same section through multi tracks, for deleting. i want to remove a specific section from several tracks at once so they will all be in sync rather than doing it one by one and more than likely not having it snyc up with afterwords.
- Quality Assurance
Re: deleting mutli tracks
Several ways, like:phantasm777 wrote:i have searchd as best i could and could not find a way to hilight the same section through multi tracks, for deleting. i want to remove a specific section from several tracks at once so they will all be in sync rather than doing it one by one and more than likely not having it snyc up with afterwords.
* Hold SHIFT and click above the mute/solo buttons in the tracks you want to include in the selection
* Drag the region up/down into the other tracks
* Hold SHIFT and Down arrow
* Down arrow and ENTER
See http://manual.audacityteam.org/index.ph ... _Selection .
