Effects dont appear
axltvojamama
Effects dont appear
My effects dont appear even after i downloaded and installed all of the plugins and all that yazz. I desperately need help!
- Quality Assurance
Re: Effects dont appear
Are they are VST plug-ins? If you are using 1.3.8 or later, check "Rescan" in the Effects Preferences and restart Audacity. In 1.3.7 or earlier, just restart assuming you have the VST bridge. See:axltvojamama wrote:My effects dont appear even after i downloaded and installed all of the plugins and all that yazz. I desperately need help!
http://wiki.audacityteam.org/wiki/VST_Plug-ins
If they are Nyquist or LADSPA plug-ins, you just need to restart:
http://audacityteam.org/download/plugins
