Join midi files
tmccar
Join midi files
Post by tmccar » Fri Sep 10, 2010 9:49 pm
I would like to join a few midi files into one, and save it as mp3. Can this be done in audacity?
Re: Join midi files
Post by kozikowski » Fri Sep 10, 2010 11:01 pm
Audacity doesn't manage MIDI. If you export the MIDI project as WAV or other sound files, then we're here for you.
MIDI isn't a sound format. It's a music instrument control format. You can't directly listen to it.
tmccar
Re: Join midi files
Post by tmccar » Sat Sep 11, 2010 1:12 pm
OK thanks Koz, I will see if I can get the files converted to mp3
Tom
Re: Join midi files
Post by kozikowski » Sat Sep 11, 2010 4:16 pm
Much better WAV, AIFF or other uncompressed format. MP3, AAC, and the compressed formats always create sound damage and you can't stop it. MP3 is a final delivery or listen to your iPod format, not a production format used to create other or different music.
