Buzzing & bass distortion when recording streaming audio wit
Nick Dee
Post by Nick Dee » Sun Sep 05, 2010 11:32 am
Buzzing & bass distortion when recording streaming audio with audacity 1.2.6. in Vista H B 32 Bit.
I've only been using Audacity for a short while & up until now, my recordings(through Headphone line in)have been fine but for some reason, all of a sudden, I'm getting buzzing & bass distortion when recording streaming audio. This only appears on the recording & isn't evident while streaming & it happens with the one online source that I rec from & also from WMP11, which I tried as an alternative to a Web based stream. As I've mentioned, I'm not too sure why this has started, because up until now I hadn't changed any settings or Volume levels, although after a few recording attempts, I did try lowering the Main Vol. but the buzzing was still evident & the bass distortion/audio was simply quieter. I've tried updating my Realtek Hi Def Audio drivers in Device Manager but it was up to date, so I used Driver Robot to scan, review, update & install but the problems still persist. Pls Pls Pls can anyone offer me any assistance with this annoying set back?
Thanks in advance[Hopefully? ; )].
Audacity Prefs.
Audio I/O Tab:-
Playback Dev: MSM-O
Rec. Dev: MSM-I
Rec. Chan: 2(Stereo)
Quality Tab:-
DSR: 44100Hz
DSF: 32-bit float
R-t SRC: Fast Sinc
H-q SRC: High-qual Sinc
R-t D: None
H-q D: Triangle
File Formats Tab:-
* Read Directly
Uncomp. Exp. Format
WAV (Msoft 32bit Float)
OGG Exp. Setup
OGG Qual. 5
MP3 Exp. Setup
MP3 L V: LAME v3.98
Bit Rate: 320
Windows Sound Settings.
Playback Tab:-
Speakers: Realtek H D A = Working Rec. Tab:-
Mic: Disabled
Stereo Mix: Realtek H D A = Working
Master Vol. set at 97.
[All the above worked fine for months].
Re: Buzzing & bass distortion when recording streaming audio
Post by steve » Sun Sep 05, 2010 2:03 pm
See the reply to your duplicate post: http://forum.audacityteam.org/viewtopic ... 62#p101562
