How can this latency problem be corrected?
chillowack
Post by chillowack » Sun Aug 29, 2010 10:33 pm
I'm trying to record some vocals over music, and as I'm singing, on the headphones I hear myself singing half a second later than I actually sing. This is distracting, and it's messing with my timing; plus I have to manually move the lagging vocal track after it's recorded, to get it into the right place.
Is there a way to eliminate this latency? Some setting maybe, that I can adjust so that this doesn't happen?
(If this has already been dealt with elsewhere, please point me there. Thanks for your help.)
Re: How can this latency problem be corrected?
Post by Gale Andrews » Mon Aug 30, 2010 4:10 am
chillowack wrote:I'm trying to record some vocals over music, and as I'm singing, on the headphones I hear myself singing half a second later than I actually sing.
Playback latency is expected if you are using software playthrough. Try using hardware playthrough instead as described in this Frequently Asked Question. Otherwise you'll need some kind of external recording interface that offers hardware monitoring.
chillowack wrote:plus I have to manually move the lagging vocal track after it's recorded, to get it into the right place.
Recording latency is also expected. It can be adjusted for at "Latency correction" at Edit > Preferences: Recording, and thus eliminated if the latency is constant. See Latency Test in the Manual for how to measure the latency.
chillowack
Post by chillowack » Tue Aug 31, 2010 1:50 am
Thanks Gale, I appreciate your help!
