How to know volume?
Re: How to know volume?
Post by kozikowski » Thu Aug 26, 2010 5:20 pm
You may not be able to export a WAV of the show. Something that long will create a WAV over 5GB and I believe the limit is either 2GB or 4GB.
Long performances -- essentially surveillance recordings -- are magic. You run into many computer limitations and nasty surprises.
Post by steve » Thu Aug 26, 2010 5:51 pm
kozikowski wrote:You may not be able to export a WAV of the show. Something that long will create a WAV over 5GB and I believe the limit is either 2GB or 4GB.
The maximum size for a WAV file is 4 GB. The 2 GB limit is imposed by some (usually older) computers.
My recommendation would be to export the recording in chunks of no more than an hour (~600 MB for 16 bit 44100 stereo WAV).
Select ~1 hour. File menu > Export Selection.
