Am I able to export with the above CCIT U-Law format?
Juggling back and forth with Audacity and Sound Recorder is becoming painful and can affect the quality of the final wav.
Thanks in advance,
Martin.
CCIT U-Law, 8kHz, 8-bit, mono
marvwilliams
Re: CCIT U-Law, 8kHz, 8-bit, mono
For "ADPCM U-law CCITT 8 bit" select "Other Uncompressed Files" as the format in the Export Dialogue screen, then click on the Options button and select WAV > U-law
For a 8 kHz bit rate you need to set the Project Rate to 8000 before you export (bottom left corner of the main Audacity window.
- Quality Assurance
For many telephony applications, this won't work because Audacity exports a non-standard 16-byte fmt chunk. We are considering changing to 18-byte for WAV (Microsoft) headered U-Law and A-Law. Please test an example 18-byte file at http://forum.audacityteam.org/viewtopic ... 71#p132371 .steve wrote:For "ADPCM U-law CCITT 8 bit" select "Other Uncompressed Files" as the format in the Export Dialogue screen, then click on the Options button and select WAV > U-law
