New to the Audacity program but decided to give it a shot as I can't seem to find any way to convert some old DOS game MIDIs to WAV files for personal listening in the car.
I'm using Windows XP w/ a Sound Blaster X-Fi sound card.
First off, let me clear the fact that Audacity plays WAV files and MP3 files just fine on the speakers. The problem occurs when I import a MIDI file, it is unable to play back the audio. Additionally, whenever I export to WAV the resulting WAV file is only 44 bytes in size and when opened in a text editor displays just a file header as shown below.
RIFF$ WAVEfmt D¬ ˆX data
Any ideas on how to get this functioning properly?
Problems with "Import MIDI"
Re: Problems with "Import MIDI"
Audacity does not support playing MIDI files.
MIDI files do not contain "audio" - they are just a list of instructions that tell a synthesizer which notes to play. http://en.wikipedia.org/wiki/Musical_In ... _Interface
The only MIDI support that is currently implemented is displaying MIDI data. http://manual.audacityteam.org/index.php?title=Tracks
To "Record" a MIDI file with Audacity you play the MIDI file in a MIDI player of some kind (for example Windows Media Player can play MIDI files) and then record the output into Audacity. There is a page about recording sounds that are playing on your computer here: http://wiki.audacityteam.org/wiki/Recor ... e_computer
Alternatively, MIDI files can be rendered directly to audio using programs such as Timidity. See here for some suggestions: http://stackoverflow.com/questions/1185 ... v-mp3-in-c
