I have recently installed Audacity 1.3.12 Beta (unicode) on Windos 7 to digitallize some old cassetes tapes.
The problem is that in my <Effect> menu don't appear some effects I need and, I understand, should be there by default as: Amplify, high pass filter, etc. The only effects appearing in my menu are: Fade in, Fade out, Leveller, Noise removal, Normalize, and Trucate silence.
Not whithstanding, I can see 16 effects files (*.ny files) in my plug-ins folder:
C:Program Files (x86)Audacity 1.3 Beta (Unicode)Plug-Ins.
Any help to get Audacity recognising the plug-ins would be appreciated.
Yours - Huaca
Cannot detect effects inf the plug-ins folder
Re: Cannot detect effects inf the plug-ins folder
Go to "Edit menu > Preferences > Interface" and ensure that "CleanSpeech Mode" is not selected.
OK. Thank you very much.
