Need help importing my EQ curves
rhythmonster
Hi, I need help importing my EQ curves into Windows XP. I have my xml file from my home folder in Linux but I'm not sure where to put it to get recognized. Thanks in advance.
- Quality Assurance
Re: Need help importing my EQ curves
Assuming you are using 1.3.12 or before, EQCurves.xml goes insiderhythmonster wrote:Hi, I need help importing my EQ curves into Windows XP. I have my xml file from my home folder in Linux but I'm not sure where to put it to get recognized. Thanks in advance.
Documents and Settings<user name>Application DataAudacity
on Windows XP.
rhythmonster
Thank you!
