Find Silence and Multiple export
wmiked
Post by wmiked » Fri Aug 06, 2010 6:30 pm
Hi,
I am copying my vinyl and tape audio to MP3 format on my PC. To speed up the process I tried to use 'FIND SILENCE' and 'EXPORT MULTIPLE' commands. Neither appear on the FILE or EFFECT menus.
The find silence module appears in the PLUGIN folder.
How do I invoke these features or is my install corrupt?
Thanks
WMikeD
Re: Find Silence and Multiple export
Post by Gale Andrews » Fri Aug 06, 2010 10:23 pm
Repeating the answer I gave you when you wrote to [email protected]:
Have you accidentally checked "CleanSpeech Mode" in the Interface Preferences?
http://manual.audacityteam.org/index.ph ... nces#Modes
This would remove Export Multiple from the File Menu and all of the Analyze menu, which is where Silence Finder appears. This would still hold true even if you had SilenceMarker.ny in the Audacity Plug-Ins folder.
If that does not solve the problem, perhaps you did not obtain Audacity from us. You can obtain an unmodified copy here:
