Autotune Plug-In doesn't show up
RaW
Post by RaW » Thu Jul 29, 2010 1:09 pm
Hi,
I'm using audacity since today and downloaded a Autotune Plug-In (http://www.audacityteam.org/vst/)
I copied the file from (C:)>Program Files(x86)>Audacity to (C:)>Program Files(x86)>Audacity 1.3 Beta>Plug-Ins
But it wont show up in the effects, or any other tab.
When I start Audacity it says 'Loading Plug-Ins' but when its loaded the autotune plugin is nowhere. :(
Any help?
(I'm using Windows 7)
- RaW :mrgreen:
Re: Autotune Plug-In doesn't show up
Post by steve » Thu Jul 29, 2010 2:01 pm
I don't think that Antares Autotune is supported by Audacity.
A similar (free) effect called GSnap is partially supported. http://www.gvst.co.uk/gsnap.htm
RaW
Post by RaW » Thu Jul 29, 2010 3:51 pm
Thanks!
How do you have to set it to t-pain settings?
Post by steve » Thu Jul 29, 2010 5:26 pm
There are several "tutorials" on YouTube describing how to get a T-Pain effect with G-Snap on Audacity. However, for a full T-Pain effect you need to set the effect to track a MIDI input (same if using Antares Autotune) but Audacity does not support MIDI. So you can get an approximation to the T-Pain effect (basically by setting everything to the extreme settings), but to get the real effect you need to use a VST host program that also supports MIDI (such as Cubase, Sonar, Reaper ...)
