effects not exporting?
videoeditor
I had a few audio track that have a consistent hiss sound, so I used the noise filter to edit it out. It worked out pretty good while I am in audacity. When I export it, it doesn't seems like anything had changed from the original track. It seems like I must have missed something really simple.... can anybody help?
videoeditor
Re: effects not exporting?
update; it seems to export fine with .ogg and flac, but not wav, mp3 nor AIFF.... : (
This is me with the deer in the headlights look.
I have no idea what could cause that........
Do any of the other effects work? If you applied a simple amplify, but really go crazy -- overdo it. Does that effect export?
You flew right by where you got the tracks from. Are these 48000, 16-bit, Stereo video WAV files?
You also said something that got my attention.
<<<I used the noise filter to edit it out. It worked out pretty good>>>
Nobody ever gets the Noise Reduction to work right the first time.
videoeditor
actually the amplifying works....
still the noise removal doesn't : (
It sounded so good in audacity, yet sounds sooooo bad in Wav
