Hello,
I installed 1.2.x and 1.3.x when installing, I accidently selected French. I have uninstalled, rebooted, used REGEDIT to search for Audacity entries and deleted them in registry.
I have deleted program files.
However, I can't get an English version to reinstall - please help.
Thank you.
Can't install English version
audacityg342
Re: Can't install English version
Some information you missed out - which operating system you are using,
For Audacity 1.3.12 on Windows, you need to edit the Preferences file (audacity.cfg) which is in this location:
Edit the second of those two lines so that it reads:
Save the file (make sure that windows does not add ".txt" to the file name, it must be called audacity.cfg)
- Windows 98/ME: WindowsApplication DataAudacity
- Windows 2000/XP: Documents and Settings<user name>Application DataAudacity
- Windows Vista and 7: Users<user name>AppDataRoamingAudacity
Code: Select all
[Locale]
Language=fr
Code: Select all
[Locale]
Language=en
audacityg342
Thank you so much!
God Bless you!
God Bless you!
