Multiple Voice Tracks
I record as podcast. I have a 4 channel mixer. I need to know how to record multiple voice tracks. Can this be done with Audacity?
Re: Multiple Voice Tracks
I asked that very thing a while ago. Audacity will cheerfully record up to 16 tracks. The trick is get the tracks inside the computer.
This is the thread...
http://forum.audacityteam.org/viewtopic ... 807#p92800
I can get multiple tracks. That's no problem. But I guess the question is how do I assign the tracks to different channels of my mixer?
Do you have a multi-channel sound card? If so, what sort?
I would guess that i do. It's a brand new Dell laptop. On Live 7 Lite, that came with my M-Audio mixer that I just got, can have each channel hooked to it's own track. I just have to sellect "audio" and it finds the next open channel.
But I can't find any settings to tell Audacity that I want a track to use a channel from the mixer.
Audacity currently only supports a maximum of 2 channels for playback (stereo), though you can export multi-channel audio files if you have some means of playing them.
What sort of M-Audio Mixer do you have (model number?) and how is it connected to the computer?
It's a Fast Track Ultra hooked with USB. I record voices in mono and lay sterio music beds underneith. But we have 3 hosts for the show and I need to have 3 channels from the mixer each using one audio track on Audacity.
I guess this won't be the first time.....
------------ M-Audio Help Forum --------------
Are you using the M-Audio ASIO driver?
In your recording softwareís audio preferences, make sure that you learn how to select the M-Audio ASIO driver rather than the MME, WDM, ASIO4ALL or Multimedia ASIO drivers.
Audacity doesn't directly support ASIO driver software. If the unit won't work with the Windows drivers, then there aren't a lot of options.
Multiple simultaneous channel support is a sore point.
I'm a bit confused here. Are you saying that you CAN record multiple tracks simultaneously?J-Rod wrote:I can get multiple tracks. That's no problem.
I can't get one mic to record on track one, while a second mic records on track two and a third mic records on track three.
