Hi,
I generate tones, DTMF codes using Generator in Audacity 1.3 for Windows
and select generated audio files to one location, one directory.
Is there any chance to set Audacity to keep last Export Selection directory remembered
as today, default Export Selection directory is
Audacity / modules.
I don't want to change default settings for Export Selection.
Just need Audacity to keep last Export Selection directory remembered, if possible.
HoTo keep last Export Selection remembered ?
Re: HoTo keep last Export Selection remembered ?
That should happen automatically as long as Audacity closes normally and does not crash.darius2 wrote:Is there any chance to set Audacity to keep last Export Selection directory remembered
Thanks.
So to set up another default for directory as export location - preferences /submenu
and how to disable
EDIT Metadata edit form
as I don't edit metadata at all.
Just generate noise, sine wave, dtmf, save to test directory
and play by Asterisk as MOH to learn what type of sound distorsion is generated by Asterisk playing audio to a sound card via Celliax audio channel.
and how to disable
Just select the required directory once and Audacity should remember it and use the same folder next time.darius2 wrote:So to set up another default for directory as export location
There is a check-box in:darius2 wrote:how to disable
EDIT Metadata edit form as I don't edit metadata at all.
Edit menu > Preferences > Import/Export tab
Thanks.
Audacity 1.3 is really an excellent app.
What about DTMF decoder or speach recognition modules in next editions ?
