DTMG generator, DTMF analysis, decoding with Audacity 1.3
darius2
Post by darius2 » Thu Jul 01, 2010 6:22 pm
Hi,
as advised, I downloaded and installed Audacity 1.3, coming with DTMF Generator.
Did some basic tests and would like use Audacity 1.3 as recorded DTMF audio input decoder, analyzing tool.
Tried to select a part audio track for detailed analysis (spectral analysis ) as in Audacity 1.2
but failed to get select cursor to work.
Hovering over audio spectrum cursor changes to double T "I" and no chance to select a part of audio spectrum (one DTMF code).
Any idea ?
thanks
Darius
Re: DTMG generator, DTMF analysis, decoding with Audacity 1.
Post by Gale Andrews » Fri Jul 02, 2010 1:35 am
darius2 wrote:Did some basic tests and would like use Audacity 1.3 as recorded DTMF audio input decoder, analyzing tool.
Do the same as you do in 1.2 (hit F1 to choose Selection Tool then click and drag in the audio track). If it does not work, uncheck "Snap To" in Selection Toolbar at the bottom.
darius2
Post by darius2 » Fri Jul 02, 2010 9:17 am
Thanks, track selecting tool started to work.
One click changes duble T to "hand".
No change to settings, preferences.
