can't get it to record
cfarlow
Post by cfarlow » Wed Jun 30, 2010 7:10 pm
I have Windows 7
I followed the tutorial and when I get to the point where it says to click on "Start Monitoring" there is no sound going in - nothing happens. I've checked my settings over and over again. :x
I'd appreciate some help.
Thanks.
chf
Re: can't get it to record
Post by steve » Wed Jun 30, 2010 8:22 pm
Did you find this bit in the documentation? http://wiki.audacityteam.org/wiki/Mixer ... es#vistacp
Is your recording device enabled and have the volume turned up in the recording tab of the "Sound" applet in the Control Panel?
cfarlow
Post by cfarlow » Wed Jun 30, 2010 10:28 pm
Most of what is on that link, I already did. Here's the list of what I did again while I was going through those instructions.
Microphone is enabled
Show Disabled Devices and Show Disconnected Devices are both checked
There is no option to Set as Default Device.
The only options are:
Configure Speech Recognition
Disable
On the Levels tab in Properties,
Microphone is at 25%. I moved it up to 100%
Microphone Boost is 0.0 dB - I moved it all the way up to 30.0 dB
Moving the Microphone to 100% and Microphone Boost to 30.0 dB did not change anything.
Everything else checked out with the rest of the instructions in that section.
I know people say audacity can be set up to work with Windows 7. What am I missing?
Thanks for your help.
chf
cfarlow
Post by cfarlow » Wed Jun 30, 2010 11:04 pm
Actually, I did get it to record. Thanks. :)
Now I'm having a different problem ...
Everything I say is being run together and speeded up.
How do I adjust the settings so the recording sounds like what I'm saying?
thanks
chf
Post by steve » Wed Jun 30, 2010 11:43 pm
cfarlow wrote:Actually, I did get it to record
How did you do that?
What sort of microphone are you using?
cfarlow
Post by cfarlow » Thu Jul 01, 2010 12:48 am
I think what did the trick was in Audacity Preferences - Devices, I changed my recording device to microphone; I kept my playback device on speakers. :)
I'm using a headset with mic from Radioshack.
Now, I still haven't figured out how to get it to sound like I say it. It still comes out speeded up. And the more directions I read and the more I play with it, the worse it gets. Any help with this one will certainly be appreciated.
chf
Post by steve » Fri Jul 02, 2010 10:02 am
See here: http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
and pay particular attention to steps 7 and 8
7. To prevent possible sample rate or recording channel discrepancies, right-click again and click Properties then the Advanced tab, and make sure the "Default format" matches both with the project rate bottom left of the Audacity screen, and with the number of "recording channels" in the Audio I/O tab of Audacity Preferences (Devices tab in current Audacity Beta); now click "OK"
8. Click the Playback tab of Sound, right-click over the "Speakers" or "Headphones" device for your computer sound device and set it as "Default Device" or "Default Communication Device" as required; then right-click and click Properties then the Advanced tab, and set "Default Format" to match with the settings in Step 7 above
jose.erasmo1997
Post by jose.erasmo1997 » Fri Jul 09, 2010 4:57 am
I down load audicity but some tolls from the effect pain are grey and I can't use them could you help me with that please. :)
jose.erasmo1997
Post by jose.erasmo1997 » Fri Jul 09, 2010 5:45 am
I don't know if I'am having this problem maybe because I didn't download something that has those tools?
waxcylinder
Post by waxcylinder » Fri Jul 09, 2010 8:11 am
jose,
see my response in your other thread: http://forum.audacityteam.org/viewtopic ... 24&t=28949
