PLEASE HELP TO FIX IT
PROBLEM SARTING TO RECORD
WITH WINDOWS 7 SO FAR I GOT: ERROR WHILE OPENING SOUND DEVICE PLEASE CHECK THE INPUT DEVICE SETTING AND PROJECT SAMPLE RATE
Re: PROBLEM SARTING TO RECORD
what input device is selected?
what sample rate is selected ?
in Windows XP and earlier, recording inputs such as "microphone" or "stereo mix" could be selected in the Audacity Mixer Toolbar. Currently, the newer audio API in both Windows Vista and 7 means that inputs must be selected in Audacity at Edit > Preferences: Devices.
Error opening sound device when recording: Audacity is subject to Windows 7 and driver behaviour that can cause inputs to be hidden by default. Also, physical input ports such as microphone or line-in ports will not be automatically listed by Windows if there is no input connected to them. As a result of these behaviors, an error may be received when trying to record.
To solve this, go to "Sound" in the Windows Control Panel, show the disabled and disconnected inputs, then enable and make default the required input. Make sure a physical input such as a microphone or line-in is properly connected to the computer. For more detailed instructions, see the Mixer Tooolbar page ( http://wiki.audacityteam.org/wiki/Mixer ... es#vistacp )
The sample rate is 44100
I'm trying to record from youtube unfortunately the same annouce:PLEASE CHECK THE INPUT DEVICE SETTING AND PROJECT SAMPLE RATE
then select the device
in win
in the drive
in audacity
you may not be able to do what you want with
win7
some soundcards
in win
in the drive
in audacity
win7
some soundcards
Did you check out this page? http://wiki.audacityteam.org/wiki/Mixer ... trol_Paneldyaly12 wrote:I'm trying to record from youtube unfortunately the same annouce:PLEASE CHECK THE INPUT DEVICE SETTING AND PROJECT SAMPLE RATE
At what point did you get stuck?
