hello,
I got a problem , everytime I try to use for example the classic master limiter , everytime somewhere in the file that I selected , an anoying "click" comes to the surface after using this master limiter. how can I avoid that ?
thanks in advance
VST PROBLEMS
Re: VST PROBLEMS
Are you applying the effect to the entire track, or just to part of the track?
Before you apply the effect, is the maximum peak level of the entire track below 0 dB?
Do you have the same problem with 16 bit tracks and 32 bit tracks?
Do you have the same problem with tracks that have a sample rate of 44100 and 48000 Hz?
Re: VST PROBLEMS
yes i am using it on the whole track ,
where can I check if the track goes over the 0db limit ?
Re: VST PROBLEMS
and even if its under the 0db limit It does the same thing , it clips everytime ...
Re: VST PROBLEMS
It sounds as if it might be a problem with that plug-in effect.
Have you tried the "Hard Limiter" that is included in the LADSPA plug-in pack? (available here: http://audacityteam.org/download/beta_windows )
jimmy carter
Re: VST PROBLEMS
hi
i hav a problem whenever I try to use the classic master limiter , somewhere my selected file , an anoying "click" comes to the surface after using this master limiter. how can I avoid that ?
Moderator Note: a blatant advertising link has been removed from this link. For now you have been given the benefit of the doubt - but please be aware that your user account is being monitored - any further violations will result in your immediate removal from this forum. We do not tolerate spam on this forum - we run a zero-tolerance, scorched-earth policy on spam and spammers.
