I have been successfully recording radio "Listen Again" streams using Winapp, but at the end of my free trial, I was wondering whether Audacity would work (at a much preferred cost to the £36 that the Winapp people want
I have downloaded Audacity onto my Windows 7 (64 bit) laptop. After a bit of reading around the manuals and forums, I managed to find the "Stereo Mix" and enabled this option via Control Panel. However, when I return to Audacity and check the Audio device information, I can see that my Stereo Mix option has no supported rates. In Control Panel, I set the rate to 44100, but this is not reflected in Audacity.
Next I checked my Driver Card settings - it is VIA High Definition Audio. When I looked at the driver details, I noticed that the drivers were located in the Windowssystem32 subdirectory. Does this mean that there is a clash between the 64 bit operating system and a 32 bit sound driver? If so, is there any workaround?
I am not a hardware person or particularly technical with operating systems and drivers so please bear this in mind if you ask me a question.
Many thanks for your help.
Here's the output from the Audacity:
Default capture device number: 1
Default playback device number: 4
Device ID: 0
Device name: MME: Microsoft Sound Mapper - Input
Input channels: 2
Output channels: 0
Low Input Latency: 0.200000
Low Output Latency: 0.200000
High Input Latency: 0.400000
High Output Latency: 0.400000
Supported Rates:
Device ID: 1
Device name: MME: Stereo Mix (VIA High Definition
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 2
Device name: MME: Internal Microphone (VIA High D
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 3
Device name: MME: Microsoft Sound Mapper - Output
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 4
Device name: MME: Speakers (VIA High Definition A
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 5
Device name: Windows DirectSound: Primary Sound Capture Driver
Input channels: 2
Output channels: 0
Low Input Latency: 0.000000
Low Output Latency: 0.000000
High Input Latency: 0.000000
High Output Latency: 0.000000
Supported Rates:
Device ID: 6
Device name: Windows DirectSound: Stereo Mix (VIA High Definition Audio)
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 7
Device name: Windows DirectSound: Internal Microphone (VIA High Definition Audio)
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 8
Device name: Windows DirectSound: Primary Sound Driver
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 9
Device name: Windows DirectSound: Speakers (VIA High Definition Audio)
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Selected capture device: 1 - MME: Stereo Mix (VIA High Definition
Selected playback device: 4 - MME: Speakers (VIA High Definition A
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Available mixers:
Available capture sources:
0 - Internal Microphone
1 - Microphone
2 - Stereo Mix
Available playback volumes:
0 - PC Speaker
1 - Internal Microphone
2 - Microphone
3 - Wave
Capture volume is native
Playback volume is emulated
