cut and paste with windows 7
[email protected]
Post by [email protected] » Sat Jun 19, 2010 1:14 am
I use WIndows 7 and Audacity 1.3.12 and before 1.3.10. WIth both, I sometimes get no response when I select part of a track and click "cut" on the menu. Likewis the paste command sometimes does nothing. Other commands continue to work. So I am unable to do any meaningful work when this happens.
Re: cut and paste with windows 7
Post by Gale Andrews » Sat Jun 19, 2010 11:55 pm
[email protected] wrote:I use WIndows 7 and Audacity 1.3.12 and before 1.3.10. WIth both, I sometimes get no response when I select part of a track and click "cut" on the menu. Likewis the paste command sometimes does nothing. Other commands continue to work. So I am unable to do any meaningful work when this happens.
Is it 64-bit Windows 7? Is this more likely to occur with long tracks or selections (say over half an hour long)? Does the cut/paste occur if you wait, or if you repeat the command? Does using the keyboard shortcuts instead of buttons help?
Have you tried clicking over audacity.exe in Explorer > Properties and changing compatibility to a Vista or XP option?
