recorded something on Audacity earlier and then saved and exported it. For some reason, the export had no sound so I decided to re-open the raw file in Audacity and export it again.
However, when I checked the data, it was in like a hundred parts, about 6 seconds long each (screenshot at the bottom). When I right click -> open with Audacity it just opens that 5 second long audio and if I highlight them all and drag them into Audacity it doesn't magically arrange them all, but puts them all on a separate layer (or whatever it's called in Audacity
So my question is how can I open these small files in Audacity, short of manually placing every single one in order..
I'm pretty sure this is a really dumb question - but I checked the 'read here before posting' board and then did a search and came up with nothing. Probably because no-one has been stupid enough to need help with this before
Thanks for any help.
