Crazy Feedback??
helpthehelpless
Crazy Feedback??
Post by helpthehelpless » Mon Jun 07, 2010 9:02 pm
I get this crazy feedback that starts out small and rises exponentially to an insane level in like 3 seconds whenever i try to record. I am using the beta for windows 7. Can anybody help??
helpthehelpless
Solved...
Post by helpthehelpless » Mon Jun 07, 2010 9:26 pm
wow, um...I found the answer here I am pretty sure http://www.ehow.com/how_5319319_stop-fe ... acity.html
It seems to have worked. if you have this problem, check out the link!
Re: Crazy Feedback??
Post by steve » Tue Jun 08, 2010 12:47 am
helpthehelpless wrote:I am using the beta for windows 7
You posted in the Audacity 1.2 part of the forum - no problem, I'll move it.
In Audacity 1.3.12 there is a much quicker way of switching off software playthrough - click on the "Transport" menu and it is listed at the bottom of the menu.
(Software Playthrough is off by default and for most Windows users that is the correct setting - one of the few cases where you may need to switch it on is if you are recording from a USB turntable and wish to monitor the recording through your computer speakers. In almost all other cases it should remain off (not selected).
