Lost Microphone USB Codec
idiotmitten
Post by idiotmitten » Mon May 31, 2010 10:13 pm
Windows 7. I accidentally deleted the recording icon for the USB Codec. I didn't think it would immediately delete it but it did (didn't need APPLY). How do I get it back?
Paul
Re: Lost Microphone USB Codec
Post by Gale Andrews » Mon May 31, 2010 11:05 pm
idiotmitten wrote:Windows 7. I accidentally deleted the recording icon for the USB Codec. I didn't think it would immediately delete it but it did (didn't need APPLY). How do I get it back?
If you are talking about the "Sound" applet in the Windows control panel, right-click anywhere while you are on the Recording tab and check "Show Disabled Devices" and "Show Disconnected Devices". If the USB codec does not reappear, make sure the USB cable is properly connected at both ends.
You can read how to set up and record from USB devices on the Wiki.
idiotmitten
Post by idiotmitten » Tue Jun 01, 2010 1:11 am
That worked. Thanks. I never would have thought of doing that.
Paul
