Problem with Export Multiple 1.3.10
orgelquaeler
Post by orgelquaeler » Thu May 13, 2010 4:50 pm
Hey Guys! Been Awhile!
Having an issue with Export multiple. What I am doing is recording spoken word, and splitting the long files into a few separate tracks. I have been able to use Ctrl-B to split tracks, then "Export Multiple" for its intended purpose. When I compile the CD, I use no silence between tracks so the audio plays seamlessly. However, Audacity has gone and saved about a seconds worth of audio from before and after the break and saved it into the opposite files, so instead of playing seamlessly, there is a slight repeat between files. I am assuming this is what the function of the "Cut Preview" value is in the Playback tab under preferences, which was by default set to "1".
For goodness sake, this should be set to "0" by default. I can bet this has caused much frustration. Of course, I haven't been around here much lately, so maybe this problem has been addressed, or perhaps it has nothing to do with "cut preview".
waxcylinder
Re: Problem with Export Multiple 1.3.10
Post by waxcylinder » Thu May 13, 2010 4:51 pm
This sounds like a bug that we had in 1.3.10 or 1.3.11 - it should be fixed in 1.3.12
1.3.12 seems to be a pretty good release - the best for a while ...
Post by steve » Thu May 13, 2010 4:58 pm
Yes it was a bug in 1.3.10 (Export Multiple and Export Selection rounded the length of the exported audio to 5 seconds).
It is now fixed.
orgelquaeler
Post by orgelquaeler » Thu May 13, 2010 5:20 pm
Alright. Thanks guys. Will see how that works out.
