Help needed with automation and tone generation
baitz
Post by baitz » Sat Apr 17, 2010 11:51 pm
Hello everyone,
I was wondering if there's anyone here with the time to help me with a problem. I'm trying to make a chain that will allow me to add tone to a stereo track, with different pitch for each channel. I don't realy know where to start. Is there an option to record commands made through the gui so I won't need to use nyquist?
Thank you very much for your help.
baitz
Re: Help needed with automation and tone generation
Post by steve » Sun Apr 18, 2010 5:32 pm
The "Generate" functions are not currently supported by Chain commands.
To create a stereo track with a different tone in each channel:
First create your two tones as mono tracks.
Place the tone that you want to be the Left channel above the tone that you want as the Right channel.
Click on the name of the upper track and select "Make Stereo Track" from the drop down menu.
