MP3 Bit Rate
jdmiller
MP3 Bit Rate
Post by jdmiller » Tue Apr 06, 2010 5:39 am
In the stable version of Audacity, you can change this via Edit->Preferences File Format tab. How do you do this in the beta version (ie: this option appears to be missing in the preferences area)??
Thanks
Re: MP3 Bit Rate
Post by kozikowski » Tue Apr 06, 2010 5:44 am
That's correct . Audacity 1.3 lets you set it individually for each export at the export step.
waxcylinder
Re: MP3 Bit Rate
Post by waxcylinder » Tue Apr 06, 2010 8:13 am
<<Audacity 1.3 lets you set it individually for each export at the export step.>>
Use the Options button in the export dialog box.
jdmiller
Re: MP3 Bit Rate
Post by jdmiller » Sun May 02, 2010 1:32 pm
Sorry for the delay in getting back to you with a reply. It has been a while since I ran sound...
I cannot find an "Options" button on the "Edit Metadata" screen.
I'm guessing that I am looking at the wrong place.
Thanks!!
waxcylinder
Re: MP3 Bit Rate
Post by waxcylinder » Sun May 02, 2010 2:21 pm
I have my Audacity metada stuff turned off so I don't see this window anymore.
IIRC when you move from the metadata editing to the next window you should see the Options buttion on the actual export dialog window.
Tamerz
Re: MP3 Bit Rate
Post by Tamerz » Wed May 05, 2010 10:27 pm
I had a hard time finding this as well. When you choose where the file will be saved, the option button is right below the "Save" and "Cancel" buttons.
jdmiller
Re: MP3 Bit Rate
Post by jdmiller » Sun May 30, 2010 1:02 pm
Found it.
Yea!!
Thanks to all who helped me out...
