Editing Metadata
asherman
Editing Metadata
Post by asherman » Sun Apr 04, 2010 1:34 pm
Is there any way when exporting a recorded album, that the artist, album name, date amd genre, can be automatically added to all tracks rather than having to type it in for each one? Also when I did this for WMA export, the added info did not show up on the exported files. What have i done wrong?
Anne
Irish
Forum Crew
Re: Editing Metadata
Post by Irish » Sun Apr 04, 2010 5:38 pm
Yes, go to File > Open Metadata Editor, fill in the data you want common to all tracks, and Save as a Template.
It will appear for each track when you Export Multiple.
Support for metadata is not standardised, and varies between file formats and applications. I'm not sure to what extent WMA supports it.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
whomper
Probationer
Post by whomper » Sun Apr 04, 2010 9:50 pm
Irish wrote:...
PO'L
seems to depend on the ap used to play the wma.
some show the info , some let you dig to see it, some ignore it.
asherman
Post by asherman » Mon Apr 05, 2010 12:30 pm
Thanks for the info on the template, that works well, but a waste of time a the moment as I cannot see the info in Windows Explorer (XP Home), regardless of if I export to Wav or even MWA.
whomper
Probationer
Post by whomper » Mon Apr 05, 2010 3:49 pm
you may see it in WMP or other players though
asherman
Post by asherman » Mon Apr 05, 2010 4:16 pm
No I could not see through Media Player either, but I did find that MP3 export works fine, so I will use that.
Thanks for your help.
