another installation problem (Stream error)
Rogue
Post by Rogue » Sun Apr 04, 2010 9:37 am
Hello everyone,
since version 1.3.11 I'm unable to install Audacity on my PC.
As soon as I double click the .Exe-file, the following error message shows up:
"Stream Read Error"
I don't even come to the install-menue.
I have Windows 2000 and the PC where I want to install Audacity is an offline-PC.
May this be the reason ?
Best Regards
Irish
Forum Crew
Re: another installation problem (Stream error)
Post by Irish » Sun Apr 04, 2010 12:28 pm
Try the zip version of the download.
The zip version of 1.3.12 is available here:
http://audacity.googlecode.com/files/au ... 1.3.12.zip
Copy the zip file to your offline PC and extract to the directory where you want Audacity to reside, (Usually C:Program FilesAudacity)
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
Rogue
Post by Rogue » Sun Apr 04, 2010 9:46 pm
HI,
thanks for the hint....now it works.
