Converting .aup file to MP3 format
EddieReynolds
Hi. I have saved several files in the .aup format. I have been requested to convert one of them into MP3 format. I am using Audacity 1.3.10 Beta......Windows Vista .....and have downloaded a Lame MP3 encoder (BonkEnc v1.0.14) Can you PLEASE help me? Thank you in advance. Eddie.
Re: Converting .aup file to MP3 format
That's the wrong MP3 software. You need to get the "lame" software from the Audacity page.
http://audacityteam.org/download/beta_windows
"lame" is the actual, real product name. It's not a description of the quality of the software.
Then, when you have downloaded and installed the Lame encoder, and told Audacity where to find it, (here's how),
http://audacityteam.org/help/faq?s=inst ... m=lame-mp3
you have to then open your .aup file in Audacity, and use File > Export , which will export the project as an mp3.
PO'L
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
EddieReynolds
Thank you very much Koz and Irish. I will try again today....with your proposed solution.....and hope that it works as easily as you make it sound! Thanks again. Eddie.
EddieReynolds
Thanks again guys. It worked! Much appreciated. Eddie.
