Problems with VST plugin: Carillon 1.2
cpetito
Post by cpetito » Tue Mar 16, 2010 6:18 pm
I am running Audacity 1.3.11-beta on Windows VISTA Professional.
I wanted to install and try Carillon 1.2 - a Windows VST plugin from Tweakbench.
I copied the tb_carillon_1_2.dll in the C:Program Files (x86)Audacity 1.3 Beta (Unicode)Plug-Ins folder.
When I start Audacity, I get the following errors:
Can't load Module. 'Unkargherth SE Reverb'
Can't load Module. 'dehaupt CVtoMIDI_CC'
I am assuming that Carillon 1.2 depends on these modules; however, I have not been able to locate them anywhere.
Any suggestions or pointers will be appreciated.
Thank you,
Carl Petito
Re: Problems with VST plugin: Carillon 1.2
Post by kozikowski » Tue Mar 16, 2010 9:32 pm
Audacity is frequently the victim of badly written or incomplete plug ins. There was one Audacity version that never made it past startup because it would scan for plugins first. Bad plugins, no Audacity.
That wasn't popular.
Did you google for the additional software? Are they available from the product web site? Do they have a help forum?
cpetito
Post by cpetito » Wed Mar 17, 2010 1:01 pm
Koz,
Thank you for the suggestions.
I did post a question on the Tweakbench forum and it was pointed out that Carillon is an instrument and Audacity does not support VST instruments (VSTi).
Regards,
Carl Petio
