new to audactiy
new to audactiy
i downloaded audacity with the intention of taking parts of 2 songs and putting them together to create one song. the reason i needed to do this is because i could not find a legit version of "greatest hits extended" by sublime. i have one version with a recording in the beginning, like i want, but then it gets cut off early at the end. and then i have a different one that doesnt have the recording in the beginning but doesnt get cut off in the end. so what i wanted to do was take the recording from the one version and throw that in the beginning of the other one. but since im such a newbie at using audacity im having a bit of trouble.. part of it loops over and so it repeats some of the guitar in the beginning. and im not sure how to fix this. im thinking about posting what i have so far on youtube and then one of you guys could download the file and fix it for me? if one of you could do this for me that would be great! thanks so much
you can use this program to extract the file from the youtube video: http://www.dvdvideosoft.com/products/dv ... verter.htm
and heres my problem: http://www.youtube.com/watch?v=UCJ7lMvTyTk
at right about 32 seconds is where it loops. any help would be greatly appreciated and sorry for the vulgar language in the song
Re: new to audactiy
Without listening to the sound clips, your description is of an export problem that Audacity 1.3.10 has. What you export isn't what you get. Pull down 1.3.11 and try that.
Re: new to audactiy
i dont believe its a problem with audacity, its more of a problem of me not knowing how to work audacity. :/
i think you will understand what im trying to say if you listen to the audio on the youtube video
Re: new to audactiy
You want to match the quality of the two music clips so there is less of a shock at the loop point -- 32 seconds?
I think I'm going to let one of the Windows people take this one. I'm a Mac elf.
Re: new to audactiy
kinda, or just get rid of the loop overall.
thanks for trying to help though. could you possibly tell one of the windows guys to try and help me?
Re: new to audactiy
I'd just delete from 21.7 seconds to 30.9 seconds.
Re: new to audactiy
when i try to do this, it always selects by whole seconds, how do it select by tenths or hundredths of a second? thanks for having the patience to put up with me! im new with this kinda stuff
waxcylinder
Re: new to audactiy
You just need to turn off the "Snap To" - see bottom left corner of the Audacity window - go there and un-check the tick-box.
Re: new to audactiy
thank you so much lol. i knew it was gonna be something stupid. thanks again man
