How to make gap between songs?
soundman10
My CD player won't skip the songs. It skips the songs if it play CD that was bought in a store, but not that I recorded on Audacity. I have to listen CD from the begining to the end istead of the certain songs. What need to be done in terms of recording so that CD player can skip songs? I use Windows XP and Audacity 1.3.10 Beta. Thank you.
waxcylinder
Re: How to make gap between songs?
See: http://wiki.audacityteam.org/wiki/Split ... ate_tracks
And this may be useful: http://wiki.audacityteam.org/wiki/How_to_burn_CDs
Audacity 1.3.10 has a bug which will cause problems when you try to create multiple tracks from a single recording.
You will need to upgrade to 1.3.11, which you can get from here:
PO'L
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
