Can I record in Vox format?
jennymuse
Post by jennymuse » Wed Feb 24, 2010 9:10 pm
I need to record a voice over in vox format. Can I do this using Audacity? and How?. Thanks so much. Jennymuse
Re: Can I record in Vox format?
Post by kozikowski » Wed Feb 24, 2010 9:17 pm
Audacity always records in high quality "WAV" format higher or lower depending on its settings. After you capture the job, you can export in a number of different sound formats, but I don't think VOX in one of them. It's possible the FFMpeg plugin knows what that is.
You can also export a high quality WAV sound file and convert it to other things with Super or Switch (download).
Audacity is not a very good converter.
