i have a windows xp and audacity 1.3 beta
i downloaded the LADSPA plug-ins 0.4.15 installer did everything like it asked me too and it doesnt work
does somebody else audacity 1,3 beta with the downloaded LADSPA plug-ins 0.4.15 installer?
please let me know
LADSPA plug-ins 0.4.15 installer doesnt work for me
Re: LADSPA plug-ins 0.4.15 installer doesnt work for me
Do you have the following effects?
GVerb
Hard Limiter
SC4
Make sure that the ladspa plug-ins are installed to the correct plug-ins folder.
For a default installation of Audacity 1.3.11 this will be:
C:Program FilesAudacity 1.3 Beta (Unicode)Plug-Ins
(by default, the Ladspa installer copies the effects into:
C:Program FilesAudacityPlug-Ins
which is the default installation folder for Audacity 1.2.x)
GVerb
Hard Limiter
SC4
