**SOLUTION** FFmpeg library not detected in 1.3.xx
Re: **SOLUTION** FFmpeg library not detected in 1.3.xx
Smashing
That should make it much easier to troubleshoot in future.
I can't figure out how to find my audacity files. First problem: I can't see all the files through vista windows folder search. Only a few files idiosyncratically listed (in my opinion anyway). Second problem: I can see all the files in version 1.2.6, which were recorded there, but not in the 1.3.12-beta version. The reason I downloaded the 1.3.12-beta version is because I couldn't export multiple files in mpeg format for 3 of my recordnings. I kept getting the "can't open file" error. In one of the recordnings it exported 14 of 17 tracks and then said it couldn't open the file. I figured it was some bug in 1.2.6. But I can't even find the files in the 1.3.12-beta version, so I can't check out whether it was some bug. I tried downloading the file you wrote about, but that didn't help either.
aardvark2zz
You should open another topic.
As for Search, yes vista search is a BIG pain in the arse. There are several bugs !!
The programs folder (and many others) are not normally indexed. But, they can be included.
I've had to re-index all my files because the index became corrupt.
ForgottenOne
Um, I found this solution. Read the first post of the thread, I made the thread with that post.
wow....
wow....
