How to nudge the cursor?
Mick Berg
Post by Mick Berg » Tue Feb 23, 2010 7:33 pm
I'm surprised that I can't work this out, as I've used lots of audio editing software and this is a fundamental function. How do I nudge the cursor just a tiny amount in Audacity? I just can't seem to be able to do it.
BTW many thanks to the creators of this great program.
Thanks,
Mick Berg.
Re: How to nudge the cursor?
Post by steve » Tue Feb 23, 2010 8:31 pm
Make sure that you do not have "Snap To" selected (near the bottom of the main Audacity window toward the left).
You should then be able to do a number of "nudge" type things - try the left right cursor keys, then try while holding down the Shift Key, then again with Shift+Ctrl keys.
Mick Berg
Post by Mick Berg » Tue Feb 23, 2010 9:08 pm
As usual, a minute after I posted I found out how to do it!
Thanks anyway,
Mick Berg.
