muddied recording (streaming audio)
mike190
Post by mike190 » Sat Feb 20, 2010 5:23 am
Hi. (newbie) I've used Audacity for some time to work music files. Just now tried to actually record streaming audio with Beta 1.3. The recording is muddied, garbled and has a distinct echo to it. Previously I used SoundTap for recording streaming audio....which worked great (but unusable with Win 7) Any ideas where I went wrong? Thanks
Re: muddied recording (streaming audio)
Post by steve » Sun Feb 21, 2010 3:59 pm
If you are using a laptop or any other computer that has a microphone, you are probably recording from the microphone instead of "Stereo Mix".
To record sounds playing on your computer you should ideally set the default recording input to Stereo Mix by going to the Windows Control Panel and setting it there.
See here: http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
mike190
Post by mike190 » Wed Feb 24, 2010 12:05 am
stevethefiddle wrote:If you are using a laptop or any other computer that has a microphone, you are probably recording from the microphone instead of "Stereo Mix".
I have stereo mix enabled and all other disabled...still muddied and echoing recording.....i'm mystified. thanks
Post by kozikowski » Wed Feb 24, 2010 12:46 am
If you changed settings, did you restart your machine?
I have a license for Total Recorder and that gets along with Vista, and probably Win7 by now.
You can try to work at this upside down. Can you make a clean recording from your built-in microphone?
